Fast Willy
- Joined
- Apr 20, 2015
- Messages
- 33
- Reaction score
- 0
Hey guys,
I originally bought this to do the axle swap on my 01 f250 but the wife has since given me the ok to buy a new truck so I'd rather not go any further with the swap and just sell this and my old truck.
This chassis is an 08 and it comes with the following:
- Front and Rear axles 4x4 (3.73) gears
- All from Steering components including trac bar, drag link, pitman arm, steering gear box and also the shaft from the gear box to to the steering shaft. (This was one of the most complicated parts of the swap without this piece)
- Fuel Tank complete with pump assembly.
- rear hitch is still on the frame
- some electrical is still there but most was just cut
- Comes with 17 rims with 4 good tires
- rear emergency brake and all brake lines on axles still there.
- All Brakes are in good working order and pards still have some life
- Leveling kit in front and larger block in rear
- From and rear sway bars
- Radius arms
Everything you need to do this swap is there. If you have any questions at all please call or text me at 954-801-6038 or you can pm me here.
Asking $2500 and can possibly help with delivery depending on location. I am located in Ft. Myers FL
- Radius arms
