1 Pyro feeding 2 accessories
GotStroke
Haleyville, Al.
I currently am running a Snow Performance MPG Max kit which uses a aftermarket pyro. I'm swapping out manifolds and before I install them I want to drill and tap my holes.
My question is do I need to have a pyro for my snow kit and my gauge or can I hook my gauge into the same pyro as my snow kit without messing the readings. I'm wanting to run a dual ISSPRO EGT gauge and snow kit.
blk350on20s
You should be able to do both depending on how the pyro is. If its like a normal pyro with open connectors at the end then you can attach each side of your egt gauge and water meth kit to each side of the pyro.
GotStroke
Haleyville, Al.
Thanks, just curious if anyone had actually done it and idk if different gauges had to have specific pyros or not. Ill post some pics and data when I'm done.
