1000+HP 6.4 part out
lil_fenner08
eastern iowa
So I have decided to part out my newly acquired triple turbo 6.4 king ranch and return it back to stockish. Everything listed is still on the truck is in full running condition and I will want to have the motor sold first before I start selling other parts off of it so the buyer can hear it run and drive it. Built was complete this spring.
Engine: Silverline performance built 6.4, .020 over pistons that are ceramic coated and delipped, balanced bottom end, R&R rods, O-ringed heads by Wes Beech, Cryo-treated rockers and main bearings. Heads were completely got through with new rods, springs and lifters. Head studs. Engine was broke in on the dyno at 15,000 lbs for 15 minutes and the rings set perfectly. $5000
RCD built 100s flowtested injectors $2800
RCD CP3 dual fueler kit with pump $1600
Ported intake $500
Ported fuel rails $100
I will leave it all together and a package deal, prolly will include more stuff than listed like the billet flywheel, fuel bowl ******s - $9000
Trans- John Woods full billet race 4r with compushift controller, Suncoast convertor with 200 raised stall. This will include everything needed to run on a 6.4. $6500
Low pressure fuel is a parallel system areomotive pump which I have a sale pending on
I am going to keep the triple setup for now. NOTHING WILL BE REMOVED UNTIL BLOCK IS SOLD!!! Pm me for questions and inquiries. Located in iowa.
08Monster
I'm interested in the compete engine as well.
Sent from my XT1585 using Tapatalk
lil_fenner08
eastern iowa
TTT
Price reduced
Injectors RCD flow tested 100s-2500
RCD dual fueler CP3 kit with rocker box and pump ready to go-1500
Buy them both then get the rails for free!!!!
lil_fenner08
eastern iowa
The intake is sold
Update on what i have for sale right now:
Midwest s472 kit with everything needed to run to include downpipe- 2500
Full body RCD 100s that have been balanced and flow tested-1800
Full body RCD 60s that are getting sent off to get flow tested-1500
4r100 john woods trans and stand alone controller- 10k setup- 4500 as is (Needs freshened up)
Areomotive lift pump with lines- 800
