11-16 DRW Shoes
Sterling B.
Bryan, TX
So my 2015 F350 DRW currently has 35x12.5R17s on the factory wheels with a ReadyLift lift and level that looks to be the 3" front and 2" rear kit. Lift seems way excessive for the tire size; my gut says I might be able to run the same tires on a factory suspension... spring code is CCDD
I know 35s fit on factory SRW suspension, but I don't recall off hand how the track width compares across SRW and DRW versions.
Through searching, I found the following thread regarding DRW '17+
http://powerstrokearmy.com/forums/showthread.php?t=79358&highlight=dually+tire
I've thought about pulling the front portion of the lift off and just trying it briefly, but that sure sounds like it could turn into a lot of work for nothing. Anyone ever see 35s on a factory DRW suspension and recall if any trimming had to be done? I'll trim that front air dam all day long.
pipedobber
Oklahoma
I’ve seen 305/70r 17’s on several stock, no lift duallys but not 35’s without at least a leveling kit of 2-2.5”.
