-12 Offset Pics
maxrpower
Columbus, MS
Wanting to see what a -12 offset wheel either 20x9 or 20x10 with 35s looks like on a leveled rig. Will mudflaps fit with this setup?
997.3psdiesel
Kentucky
At full lock it would rub the carpet like stuff of the fender well. Not terrible but I cut it anyways. I'll get another pic later
jgerdes2005
my 2008 f250 is has a 2" level with 18x9 with a -12 offset on 35s and it rubs at full turn on the inner fender well. you would prolly have to modify mud flaps to fit
Tom@BigTimeKustomz
Bayville, NJ
Riverside, do you have plow prep in your truck? I did the 2.5" level on my '13 350 and it sits nose high. Have a 5" block inbound to fix the problem. Just curious...
Tom@BigTimeKustomz
Bayville, NJ
Thanks for the reply. Mine is probably a half inch lower in the rear, so the taller block will give it that factory rake and it won't look goofy with the bed loaded or when towing.
DWhite
Oklahoma
I did the 5 inch block with the 2.5 leveling kit on my 6.7 and it sits perfectly level
