12v wire through fire wall
FlatbedCowboy
So I finally have time to wire in a bunch of lights and junk that Ive been putting off.
I know there is a bundle of wires that pass through the fire wall (hopefully I can find them), one is supposed to be 12v constant the other 12v with the key.
So I have three items that need to be on with the key: trailer brake, mirror heat and eventually gauges.
Three constant ones: fog lights, off-road light bar, and caution strobe.
The lights/strobe and mirror heat will be on switches. Will the 12v wires carry enough load if I have all the junk on at the same time? Or should I find different power sources for each?
dsberman94
Pennsylvania
There's write ups of using a small fuse box out of, I think, a ford ranger and mounting it under the hood.
