14 psi of boost WTF
GROSSpolluter
So Cal
Yes thats right....14 psi at wot. I just put my dpf back on for warranty work. Truck is slow as moe-lass-ass. Throwing a soft code egr related, do you think the egr cycled and got stuck open from all the soot running no dpf?
BFT
southern cali
What's the code? I've had EGR related codes that affected boost and turned ou to be the EBP sensor.
GROSSpolluter
So Cal
I doubt the turbo is ****. I was making 45 psi boost with h&s this morning. I'm not sure on the code number off the top of my head ill check in the morning.
kyle43335
if the egr was stuck open?
the truck wouldnt want to idle,and would be smoking like crazy...
GROSSpolluter
So Cal
P0404
Egr valve position control performance or range fault.
No check engine light, just shows up on my cts insight.
