'16 Dually Front Single Swap question
silveroneton
I am fixing to put some new wheels on my '16 DRW. The fronts will be regular wheels "SRW type" instead of the regular dually fronts. My question is, can you remove the studs that hold on the dually adapter and install actual wheel studs without removing the bearing assembly?
I understand the studs from the bearing to the adapter are too short and a different pitch than a regular stud.
Zmann
if your running a SRW wheel you will want to ditch the dually adapter
and you will also have a different bolt pattern from the rear
sample pic is a ten lug but you get the idea
silveroneton
This part I know, just unsure of how much of a pain it will be to remove the studs and replace them.
Zmann
I would count on pulling the unit bearings to do the job properly
mikeeg02
Drifting, PA
They can probably be done with them on the truck, but I wouldnt. I dont like putting the impacts through the bearing. I had to change mine on one once, and used a vice with the jaws opened enough so I could drive the stud between the jaws.
Its not much more work to pull the bearing.
EDIT: I suppose if you had a portable press then on the truck wouldnt be a bad thing. But I wouldnt do it with a hammer / impact hammer on the truck.
