throwing this up, i dont have time to work on it much now that school started.
1994 f-350 the truck had a turbo 7.3 that I swapped with a 97 powerstroke motor, motor is remaned with 120k on it, body has 300k. trans is auto and was rebuilt 20-30 k ago, has b and m shift kit 4.10 posi rear
truck is 2wd, but has a transfer case installed, so it just needs a 4wd front end swapped in, I have the 350 front leaf springs and rear blocks for it.
has gray interior, which is dirty but not in bad shape, ill clean it up when i get the chance, has reciever hitch
new parts are,
water pump
fuel pump
starter and solenoid
injector o-rings
glow plugs and solenoid
fuel filter + rebuilt fuel bowl
oil + filter
trans fluid and filter
t case fluid was changed
new u joints in rear driveshaft, I think i did all 3 but dont remember
IPR
oil pan
gaskets between trans and t case
dip stick tube
3 in turbo back exhaust
air filter
brake lines
power steering line
prob other stuff im missing, have receipts for most of it
power locks, front windows are power, have a cd player that can go with it
I have a 4x4 i beam front end that can go with it if someone wants
the truck has not been driven for a few years so it needs driven and all the bugs worked out, runs and drives as it is now though
trades considered, what you got? can work with you on price if you have cash
724-6o1-5652 call/text
