gunmaniac3521
just did a zf6 swap in my OBS and now I have a zf5 that's taking up space. build date is 05/20/1996 and has 240,000mi. on it. gear ratio is 5.08 in first and fifth is .77. it'll need a rebuild as it common with these, the 2nd gear synchros are gone. the transfer case is a BW 4407. when I drained the fluid it was clean and red.
I also have:
zf5 crossmember
zf5 bellhousing spacer
transmission mount
slave cylinder
clutch fork
shifter rod with upper and lower boot
4wd shifter assembly
I have to clutch and flywheel but they are pretty beat up.
asking 800.00 obo you pay the shipping. Id rather not part it out. thanks for looking!
I also have:
zf5 crossmember
transmission mount
slave cylinder
clutch fork
