1997 F-Superduty 11' Aluminum Flatbed $5500 OBO
Bremen, Ohio
1997 Ford F-Superduty (F-450) 14,500 GVWR, 2 wheel drive, 5 speed manual. 298,608 miles, Runs great! 11' Aluminum flatbed, 2 underslung aluminum toolboxes. This is a great work truck! Starts up right away, even in freezing temps.
Lots of new parts including - NEW Stage 1.5 Injectors (160cc/30%), Glow Plugs, Valve Cover Gaskets, UVC Harnesses, Coolant Filter, Waterpump and Radiator Hoses, Vacuum Pump, Serpentine Belt, Oil cooler orings and gaskets, New Antifreeze, New AFE stage 2 intake with Pre-Filter, TS Performance 6 Position Custom Tuned Chip, Scangauge, Pyrometer, New Single Mass flywheel and clutch, NEW 3" Downpipe, NEW Batteries, 6 NEW COOPER DISCOVER AT/R TIRES. The Tires alone were over $1000.00 and have less than 500 miles on them. Truck will also leave on a fresh oil change.
If I was keeping this truck the only thing that it would need is a new seat because its a little ripped up on the drivers side, and the drivers side fender has a dent in it. Apart from that the truck is in great shape.
The truck runs and drives great, I just have no need for it anymore, that's the only reason that its leaving.
For more information contact seven-four-zero-five-six-nine-one-three-one-nine or email us at [email protected]
All work was performed by Unlimited Diesel Performance in Bremen, Ohio
$5500.00 O.B.O or MAY trade for Jeep Wrangler of equal value
NO LOW BALLERS!!! :D
http://inlinethumb22.webshots.com/34581/2337378770101102974S600x600Q85.jpg
http://inlinethumb23.webshots.com/28886/2328122280101102974S600x600Q85.jpg
http://inlinethumb37.webshots.com/49700/2124826330101102974S600x600Q85.jpg
http://inlinethumb63.webshots.com/49790/2885790610101102974S600x600Q85.jpg
http://inlinethumb22.webshots.com/49429/2947982720101102974S600x600Q85.jpg
http://inlinethumb33.webshots.com/48032/2839384610101102974S600x600Q85.jpg
http://inlinethumb46.webshots.com/36013/2184713380101102974S600x600Q85.jpg
http://inlinethumb56.webshots.com/50039/2737807740101102974S600x600Q85.jpg
http://inlinethumb32.webshots.com/25567/2597056900101102974S600x600Q85.jpg
http://inlinethumb36.webshots.com/49827/2541877480101102974S600x600Q85.jpg
http://inlinethumb36.webshots.com/50339/2849069710101102974S600x600Q85.jpg
http://inlinethumb61.webshots.com/28540/2986656790101102974S600x600Q85.jpg
http://inlinethumb05.webshots.com/47172/2775176960101102974S600x600Q85.jpg
B.Warning
NE Missouri
Does it have a gn ball, heat/air work, any un-seen rust on cab, can you post pics of the dent in front fender? Steering still tight, can it be a reliable daily drivin service truck?
Bremen, Ohio
No gooseneck ball. Heat AND air work. No rust I can see. Steering was tight and was aligned when new tires were installed. I don't see any reason it would be unreliable. I have not installed the new batteries or downpipe yet, but it will be done before it leaves.
B.Warning
NE Missouri
Never mind. I zoomed in and could see it. I'll give you a call tomorrow. Hopefully we can work a deal.
