1997 F250 Crewcab Short bed 5 speed
Diesel_Brad
Gilbert PA
Ok guys, time for a new project.
Mind you I do NOT need to sell the truck, I just found something else that has peaked my interest.
I will NOT be giving the truck away. $25,000 is the price, yes $25,000
I have more into it than that(even thought that means squat) but practically everything has been gone thru. But it is an Odd truck that is desirable since t is a CCSB and it is STICK
Just try and find another, no less in this condition.
1997 F250 4x4 Crew Cab Short Bed
*STANDARD EQUIPMENT*
EXTERIOR
-Chrome Front Bumper
-Interval Wipers
-Tinted Glass
-Center High Mount Stop Light w/ cargo Box light
-37.2 Gallon Dual Fuel Tanks
INTERIOR
-Six Passenger Seating
-Auxiliary Power Point
-Pivoting Vent Windows
-Side Window Demisters
-Courtesy Light Switches
-Day-Night rear view Mirror
-Color Keyed Headliner(cloth)
FUNCTIONAL
-HD 5-Speed OverDrive manual Transmission(ZF5-S47)
-Power Steering/Brakes
-2 Speed Transfer Case(BW4407)
SAFETY/SECURITY
-Side Door Guard Beams
-Rear Anitlock Brake System
*OPTIONAL EQUIPMENT*
XLT pkg which includes
-Air Conditioning
-Speed Control/Tilt steering Wheel
-Power windows and power locks
-Chrome Appearance package
Factory Options
-7.3 Powerstroke diesel
-5 Speed Overdrive Manual Transmission
-Chrome Rear Step bumper
-AM/FM/CD player
-Sliding rear window
-Deluxe Two-Tone paint
-Manual Locking Hubs
-40/20/40 Cloth bench Seat
I have owned the truck since 2011 with 146k. And since purchasing it, I have upgraded many things. It did not happen all at once, but slowly over time. I will attempt to go thru to list all that has been done
*CHASSIS*
Rear
-New Rear Spring Hangers
-New Ford SuperDuty B Code Rear Springs
-Airlift LoadLIFTER 5000 Air bags(with Wireless Controller and Compressor)
-5100 Series Bilstein Rear Shocks
-5” ReadyLIFT Rear Block
-Precision Metal Fabs Stage 1 Bolt On Traction Bars
-Factory Rear Sway Bar added with Moog Bushings
-Sterling 10.25 Rear Axle Was Completely Taken Apart
*Sandblasted
*POR15(as primer)
*Valspar Top Coat
*08 SuperDuty Aluminum Diff Cover
*New Axle Seals and Pinion Seal
*COMPLETE New Brakes(shoes, hardware, wheel cylinders, drums)
*Refilled With Synthetic 75w-140
*Copper/Nickel Alloy Brake Lines
-315/75/16 Kelly TSR Load Range E Tires on 16x10 Eagle Alloy 058 Series Wheels
Front
-Original Dana 50 TTB(independent front suspension) Was Removed
-1997 Dana 60 Axle Was Added(before install the following was done)
*Taken apart and Sandblasted
*POR15(as primer)
*Valspar Top Coat
*New Axle Seals And Pinion Seal
*XRF Ball Joints
*XRF Steering Linkage
*Reman Caliper
*New Brake Pads
*New Rotors
*Cleaned, Inspected & Repacked Wheel Bearings
*Refilled with Synthetic 80w-90
-Precision Metal Fab Reverse Shackle Kit(RSK) Was Added
-New Ford SuperDuty V Code Front Springs
-5100 Series Bilstein Shocks
-Factory Front Sway Bar added with Moog Bushings
-Moog F350 Pitman Arm Installed
-F350 fFont Drive Shaft
-F350 Front T-case Yolk
-Crown Stainless Brake Hoses
-SKY Adjustable Track Bar
Transfer-case
-Fluid Flushed
-Synthetic ATF Installed
Transmission
-Rebuilt (bearings, synchronizers, seals)
-Synthetic ATF installed
Clutch
-Valair 13” HeavyDuty Organic
-Solid Flywheel
Engine (Factory California emission 120cc Injectors)
-Coolant flush with Low Silicate Coolant
-Oil Changed EVERY 3,000miles with Valvoline Premium Blue 15w-40
-Baldwin 2818 Open Element Air Filter
-Flo-Pro Stainless 3” Down Pipe and Stainless 4” Exhaust w 6” tip
-DPTuner F5 Chip with 6 Tunes(stock, high idle, drive thru, 60hp Econo, 80 Tow, 120race)
-Rebuilt Turbo with 1.0 Housing, Wicked Wheel 2 and EBPV Delete
-Early 99 SuperDuty Intercooler / Spider, & Custom Pipes Made
-Irate Diesel Stainless bellowed Up-Pipes
-Fuel Pressure regulator shimmed
-DieselSite 203* thermostat
-DieselSite Coolant Filtration System
-DieselSite Boost Relief Valve
-New Glow Plug Relay(western # 56131k)
-8 Beru Glow Plugs
-4 Ford Under valve Cover Harness
-2 Ford Valve Cover Gaskets
-New Fuel Pump And Associated Hoses
-2 Motorcraft Batteries
*INTERIOR*
-Completely gutted and cleaned
-Sound Deadener Installed On Firewall, Floor, Cab Roof, Rear of Cab and Inside Door Skins
-1/8” Closed Cell Foam Installed on Floor
-Original Carpet Was Shampooed
-Seats Were taken Apart and Shampooed
-Clear glass was Installed in Rear Doors and Rear Window, Then All tinted With 20%
-New Windshield Installed and tinted with 5% Brow and Chin
-JVC AM/FM/CD Installed (iPod capable)
-Bronco Defroster Switch Installed to Control Mirror Defrosters
-Air Lift Wireless ONE Air Compressor Mounted on Back Wall of Cab With Custom Mount
-AutoMeter 3 Pod A-Pillar Mount with Z-Series EGT and Boost Gauge(DPTuner switcher also mounted)
-Custom Fog Light & Strobe Light Switches(Strobes NOT Included)
*EXTERIOR*
-Bed, Fenders ,Hood Removed and Spacers Made to Lift Cab For Sandblasting and Painting. Fuel Tanks, Fuel Lines, Chassis Harness, Driveshafts, Hitch Were All Removed. (Cab, engine, trans and t-case were left in)
-Complete Frame and Underside of Cab Was Sandblasted, POR15 and Topcoated with Valspar Low Glare Black.
-An Extra Plate Of frame Steel Was Added Inside The Frame Rails To Strengthen The Frame. It Goes Approx From The Trans Crossmember to The Rear Shock mount.
-Good Rust Free Southern Fenders Were Sourced
-A Good Rust Free Drivers Rear Door Was Sourced
-A Good Rust Free Radiator Support Was Sourced
^All These Parts Were Sandblasted and Primed With POR15 before paint^
-A NOS Tailgate Was Sourced
-New Bed Skins(back sides Epoxy primed and painted Before Installed)
-Cervini Cowl Induction Hood
-Lund Visor
-Bushwacker Street Flares Painted to Match(not rust hiding under, I will even remove to show that, and If you don't like I can leave them off)
-New F350 & Powerstroke Emblems
-OEM Grill and Headlight surrounds
-New Headlights, Marker Lights, Taillights
-RJM Relay headlight Harness with Phillips X-tream bulbs
-ALL Exterior Lights Have Been Changed to LED
-PPG Products Were Used for Prime, Paint and Clear
-Custom Pinstripe Made to Duplicate the Obsolete Factory Stripes
-DeeZee Aluminum Diamond Plate Bed Caps and Tailgate Protector
-Under Bumper LED Back-up Lights & LED Pop-in Back Up Lights
-DeeZee Tough Steps
-Rhino Liner color matched(by previous owner)
-4 D-rings Mounted in The Bed
-Painted To Match Leer Cap
Truck now has 167k on it.
Phone is Nine 0 Eight -Three 1 Zero- Five 4 1 Zero
Most recent pics. I also have pics of the tear down and rebuild along the way...
http://www.powerstrokenation.com/forums/showthread.php?t=101438
mandkole
Northwest
GLWS-- no one is more committed to the OBS than Brad is. A very well documented rebuild and way cool truck.
jngreen
IN
Wasn't this truck a dually at one time, or was that another truck?
Nice ride, always a fan of your work.
Diesel_Brad
Gilbert PA
yes. I made it into a dually then made it back to single wheel for personal reasons
Sorry, thought I loaded pics
Headache rack NOT included
pullandpray
Dang does the guy want two? Lol idk I love my truck but if I saw 25k infront of me I would probably run with it. hopefully the deal goes through! Great looking truck love the hood
pullandpray
All orginal came from southern oregon. No rust. Maybe one or to scrapes in the paint that I can't get buffed out. Other than that very clean. I'm sure not as nice as one that just got restored bUT for a 20 year old truck it's a beauty.
Diesel_Brad
Gilbert PA
Deal fell thru.
Update. the 315s and 16x10s are NO LONGER AVAILABLE.
Stock Alcoas with 285/75/16 Hercules A/T tires are on the truck(missing center cap is on order)
If photo bucket will ever work......
