72ford250
- Joined
- Oct 16, 2013
- Messages
- 35
- Reaction score
- 0
So my truck that has 160/80 stage twos injectors and all the supporting mods seems to be impossible to tune. So the first tuner i had tune the chip was Johnathan at no limit i had problems with every tune only one tune would start the truck and the rest wouldn't and i had a harsh idle with them and lots of smoke and low power with the performance tunes.And also a very very sensitive throttle. I did call them and did work with them to try and sort out the problems that might be with the truck with no success so i had the option to send the chip back but decide not to. Next and most recent i sent the chip to ktperformance (php tunes) got the chip installed it and the truck started fine. So went for a drive well one big concern was the chip had only one tune that it is stuck in. SO idk what tune it is but switching the switch changes nothing all positions are the same. i checked the switch for breaks and ohm it out all is good there. And what ever tune it is on the chip is low power on the bottom end and what i would call a sticky throttle problem (let off the accelerator and the rpms wont drop through a shift and are stuck for a sec or two).Does any one know if this could all be a problem with my truck or is it just my luck? I mean both these tuners are very respect able company and tune tons of trucks with no problems so my truck is the common neutral here so?????:shrug:
