2000 7.3 oil leaking out exhaust
Nasty7.3
Eastern VA
The truck was leaking oil out exhaust there was no blow by and no oil in fuel. I went ahead a replaced the turbo and again oil is coming out of exhaust side of the turbo
Vader's Fury
Chesapeake City, MD
pull the turbo and see which side of the up-pipes the oil is coming from. Pull that valve cover and check the inj's bet you have a inj clamp bolt broken or a bad oring.
Blowby
Do you have an aftermarket or home made Crank Case Vent?
DEEZUZ
NO PUKESTERS
NWI
Yea you got a blown out copper. Look for the loose injector
Hopefully you find this and it didnt bend a rod
TARM
I love the pic of the trailing oil spill LOL That is classic.
I am amazed your bottom o-ring looks so good. You much have caught it quickly but then oil pouring out of your tail pipe is sort of hard to ignore.
DEEZUZ
NO PUKESTERS
NWI
That ambulance was driven to us like that... The stains are STILL in our concrete.. That was 4 months ago... It was one of our pump guys fault though, very inexperienced and didnt install the injector correctly.. When dealing with ****ty Dipaco injectors, you HAVE to put dielectric grease on the copper since there clearances SUCK and the copper falls off when pushing injector in... Hence why its all fubar....
He was so embarrassed..
Oh, and dont mind the crushed coolant bottle, someone threw it under while I was driving in... scared the **** outta me...
Arisley
Arlington, Texas
Did you ever find the coolant bottle lid. I know those will fly a long way and still leave a welt on someones calf when run over like that.
DEEZUZ
NO PUKESTERS
NWI
the red thing to the left of the tail pipe is the cap. must've bounced off mudflap
