2000 F250 Extended Cab Long Bed 4x4 Highly modded
slowstroke
Truck has 190k highway miles, Engine has 60k miles on it with forged rods. This truck was live tuned by Jody at John Wood's shop!
~ H11 Studs from WOP
~Wide Open Performance modified QSSB turbo
~John Wood custom built transmission with billet shafts
~DP Tuner F5 chip No start, stock, hi idle 40t, 60t,80E, 120, 140, 140 race, 140 aggressive------Lived tuned by Jody
~ AFE Stage 2 Intake with Proguard 7 Media --Fresh filter on it
~ Cooling Mist Water injection
~ MBRP 4" turbo back exhaust
~ Pacbrake Exhaust Brake
~ Auxiliary Transmission fan on switch
~ Boost, Water temp, pyro & trans temp autometer guages
~ Truck just had a tune up done $440
~ Good year wrangler duratracs 70% tread left
~ Powerslot cryo rotors with Hawk superduty brake pads (this was expensive) 34k miles on the brakes.
Something inside the transmission broke JW said he has a lifetime warranty on the labor.
Get the trans fixed & you are ready to have a great time with this truck
$17,500
slowstroke
Thanks I knew I was forgetting something
this setup is very streetable (smoke free in the 40t/60t if you dont lug it)
Hybrid Stage 3 injectors
Stock HPOP
slowstroke
They were from dieselsite.com he doesn't give out any specifics on the specs
Although from what I have heard they are hypermax injectors
slowstroke
I can take interior pics tomorrow
7.3psd97444
Indiana
So probobly a 238ish with a bigger then stock nozzle but not to large if your running a stock HPOP
