NoLimit7.3
2000 ford f250
Single cab short bed
2wd
New paint
All badges shaved
Paint matched bumpers & grill
08 rear bumper and tail gate
Spray In bed liner
Window tint
Stereo with 2 amps and sub
New venial floor mat
Weather tech floor mats
Leather seats power and heated
20in BMF wheels with Toyo tires 90%
Cal tracs
4 pillar Autometer gauges boost,trans temp,egt,fuel pressure
New rear pads and rotors
New ball joints, Tie Rods ex.
7.3 powerstroke, auto trans
Engine:
Forged rod bottom end
New pistons, bearings, tigged oil squirters, block sleeved too standard bore
Oem gaskets
DI cam
DI pushrods
H11 headstuds
DI port and polished heads
New injector cups
Beehive valve springs
Full force 250 100 injectors
DI regulated return with fuel bowl delete
Fass 150 75psi
Hellman sump
One piece up pipes
38r turbo
Stealth Hpop 1.1
Afe stage 2 intake
DI tuning 6 position
New icp sensor, ipr, cam sensor
Trans:
Built by DI
Billet input
Triple disk precision tc
Valve body upgrades
More clutches
And so on..
Billet flex plate
Everything has 12,000 or less miles on it.
Frame and cab have about 213,000 miles.
Truck is drivin daily miles will go up a bit.
$24,000
Any other details please pm me.
2wd
New paint
All badges shaved
Spray In bed liner
Window tint
Cal tracs
Engine:
Oem gaskets
DI cam
DI pushrods
H11 headstuds
New injector cups
Fass 150 75psi
Hellman sump
One piece up pipes
38r turbo
Stealth Hpop 1.1
Afe stage 2 intake
Trans:
Built by DI
Billet input
Valve body upgrades
More clutches
And so on..
Billet flex plate
$24,000
