2001 7.3 Core/Repair Longblock
importrepairguy
Maryland
Core or can be repaired. I'm currently removing engine from the truck.
I purchased another engine to rebuild for High power while I used the truck.
The engine ran fine, except for a misfire in cyl #8. That cylinder has 190psi compression. I have not done a leak down, Do not know if its rings, Piston or valve related. Truck has 151k miles.
It did not overheat or have any other problems, other than what is disclosed.
Truck had no modifications or chip.
Engine will be sold as is, No injectors or Turbo/Pedestal. Has Exh manifolds & Up-pipes. No Intake plenums or Spider.
Make offer shipped, Delivered or picked-up. I'm located at 21801 in Maryland.
PM for contact or questions.
