2001 F-350 Crew Cab Long Bed Dually 4x4 6spd (Heavily Modded)
NRHX2009
Elizabethville, PA
2001 F350 CCLB Dually 4x4 6spd Manual, Manual Transfer case. 185k on chassis
Truck is super clean, inside and out. No rust, no dents. Interior is about flawless. Seats are not worn through or torn. Brand new Michelin A/T tires.
Dana 60 front and 80 Rear. BW Turnover Gooseneck hitch installed.
ENGINE Mod List:
6-7K since rebuild. (Has some blow by? Works Perfectly fine though)
Billet Rods
Fire Ringed heads
ARP Head Studs
ARP Main Studs
De lipped Mahle Pistons
Gearhead Stg 1 cam
250/200 Injectors
T500 Hpop
Comp 910 Springs
Mild Ported Heads
Smith Brothers Pushrods
Compound Turbos S362FMW/68/.91 T4, with Cast S475/88/132 with 46mm precision wastegate. 40psi on tow tune 1050 degrees WOT, Hot tune 70psi, spools instantly.
Truck Mods:
DAC3 DPC421 Pcm swap
TS chip with custom tunes from Powerstruck.
Mag Hytec Diff Covers front and back
3.73 Gear Swap
Homemade traction bars
Heavy duty upgraded Rear Leaf Springs
Gauges
5" exhaust
Looks like a pappy truck but runs very well. Things that may need buttoned up are the Air Filter inlet for the S475 turbo and the Windsheild washer fluid tank has been removed. Other than that its perfect.
Selling to free up some cash to buy my Fathers 08 F450.
$22,000 OBO PM or call 717-919-7423
I'll add some more pics shortly.
TrailerHauler
Michigan
I bet that's a towing sum bich, whoever ends up with it I'm sure will be very happy!
Very cool build list.
co04cobra
WV
Very nice rig!! I'd put the 08 axles under this truck and roll..!!
Glws.. I wish I had a need for it.
NRHX2009
Elizabethville, PA
Thanks everyone for the comments. Its a decent truck, just growing out of the "everything has to be modified to hell and back" stage in life
