2001 Subaru Impreza 2.5rs
03f3507.3
2001 2.5 rs
Coupe
5spd
Within last 4k miles
Exedy Clutch
Napa Fly wheel
Napa Slave cylinder
Genuine Subaru timing belt, water pump, Tensioner, all timing pullys and gears, cam gears, crank gear, timing cover
Duralast coil
Duralast wires
Ngk plugs
New fuel filter
Perrin crank pulley
Rebuilt motor from engines us has 2 yr unlimited mileage all new gaskets, seals pistons, rings, reground cams, all new valve train
Within last 15k miles
Eibach springs
Kyb agx 5way adjustable struts
New top hats as spring seats
New front calipers rotors and. Pads
New front wheel bearings, cv shafts, tie rod ends, ball joints
new rear 02 sensor
New Radiator
New TSTAT
225/50/16 continental tires
Duralast battery
Has rally sports grill gaurd and 4 piaa yellow Off road lights two fogs two spots.
Lip spoilers and side skirts were painted white has jdm grill, head lights and corners
Factory carbon fiber trim kit and hud display
Wrx exhaust and wheels
Aftermarket head unit, speakers, amp
Bad things is it needs a new ac compressor and could use a little body work in spots but practically zero rust over the whole. Car
Im sure im
Forgetting somethings
ToMang07
Mainah!
Nice little scooby-doo.
Price? Miles? Location?
And is the warranty transferable?
03f3507.3
Sorry copy and paste owned me and left all that out price is $6,000 OBO, 217k on the chassis, located in Murray, KY and warranty will be transferable to new motor which just covers the long block.
