2002 Excursion suspension/bracket question
BK39
Texas
Photo attached. So now the vacuum hose is rubbing on the shock. Is the bracket that holds all 3 in the correct location? What's my issue here? Why is the vacuum line hitting/rubbing on the shock?
A quick little history on the truck, it had an 8 lift on it many years ago. Then I sold it, but the guy wanted it back to stock height. I know when I did the lift I moved that bracket down, but I'm pretty sure i put it back in the correct location.
Any help is greatly appreciated. Or if you are willing to simply take a pic of your truck, I'd like to compare the photos, to see where I went wrong.
BK39
Texas
Anybody? Doesn't have to be an Excursion, I'm sure the trucks are identical setups. A quick pic would be greatly appreciated.
psduser1
on the road
The bracket is in the correct spot. I've had to bend the hard line (brakeline) a bit to get the hose where I liked it.
Not enough to crimp it, obviously, just small tweaks.
I've had to slide the plastic clips around also.
