2002 F-350 CCLB for sale
PowerstrokeJunkie
Maryland
I think it's time to put my truck up for sale to see if anyone wants this thing more than I want it. Bought back in 2005, it's my first truck and has been transformed it's appearance a few times but i finally settled on what it looks like now, and it's just getting old for me. I love the truck and i'm not dying to sell it (because i probably will regret it) but I really really want to get into a newer truck after riding in a few of them..
Outside: Gray crew cab long bed, 137000 miles, 07 front end with harley headlights, heat extractor hood, 30% windshield, 20+5 side/rear windows, 20x9 XD spy wheels with 80% 305/55r20 nitto terra grapplers, painted tow mirrors with turn signals and recon smoked lenses/cab lights, recon 3rd light and tail lights. Redhead steering gear tapped for a custom steering ram that replaces one of the dual steering dampers, warn premium hubs, 8 trumpets total (two sets) air horns, viair 380c compressor with tank, B&W turnover ball gooseneck hitch, retrosolutions 5000k HID's in headlights and fogs,
Inside: interior was completely stripped and Bquiet ultimate on the doors, floor, rear wall (2x) and ceiling, rockford fosgate punch 450.4 amp'ed pioneer speakers, 2x 10" Image dynamics subs in SCS box behind seat with rockford fosgate punch t400 amp, double din head unit, under hood 100amp circuit breaker. gauges: exhaust temp, boost, mech backpressure, scanguage, fuel pressure and rear air bag pressure. Interior is mostly stock, will need a new seat bottom for drivers seat but i'll take care of that. Other than that interior is 9/10
Under the hood: forged rod OBS engine with about 200,000 miles with amazing compression numbers (420ish on all as of this spring) with new bearings within the last year, same time fresh ported heads, gear head stage one cam... shimmed 910 springs, smith brothers pushrods, ARP head studs, DI headers coated black, Irate wastegated t4 mount with Precision 46mm gate, s366/74/.91 with turbine blanket, 4" downpipe into 5" straight pipe with 6" tip, swamps/coolingmist water injection kit 7 gallon tank, two 250psi pumps and three nozzles with in-cab smart controller in a f-650 manual dash bezel, swamps 250/80 hybrid injectors, Hellman sump, 5/8" to an airdog2-165, 1/2 line to a custom four corner fuel feed regulated return, Stealth dual pumps (old school, with just a few thousand miles on them) fed and Ipr returned by a dieselsite spacer, dual optima yellow tops, melling LPOP, AFE big boost,
Drivetrain: BTS trans, custom rear driveshaft u-joint scatter shield, custom made (me) four link rear suspension utilizing goodyear air bags manually controlled in the f-650 dash panel using Firestone Riderite gauge and valves, front custom made ladder bar to trans cross-member, rear detroit truetrac differential, mag-hytec rear diff cover, bilstein shocks.
There is probably alot more i'm not including as of right now this is just what has come to mind as i'm typing this. It's an extensive list and i know i'm certainly not going to get what i want back out of it, however being reasonable to a point i think how it sits after tying up a few loose ends i've been putting off, i feel $25,000 is fair price. Yes it's far from KBB and i don't need you telling me how overpriced it is in your opinion, there's someone out there looking for just this though and it's going to be worth it to them, this is who i'm looking for here, not just someone looking for a gray 02 pickup. It's not perfect on the outside, it IS 10 years old, and it has a couple scratches and dings, however they are minor compared to the appearance of the truck. I have some rust starting on the fender wells of the bed, it is what it is. It would pain me but i think i could return it to stock and sell it closer to the going price for a 02 with 137k miles and make some money off the mods, and if someone is interested in the truck in stock form (power wise, aside from suspenion that's staying) i could part out the performance mods, but not yet. Yes i know you'd be interested in this or that but i want to see if anyone is interested in the complete truck as it is now. Thanks for looking, let me know if you're seriously interested and i can go into more detail with you.
PowerstrokeJunkie
Maryland
Yes the truck has the perfect setup.... I have done all the undesirable mods in the last few years learning what not to do, and finally settled on a badass street truck setup that sounds good, looks good, and runs even better. It flat out hauls ass when I want to, and I can hook up to a gooseneck and pull around 25,000lbs like nobody's business.
Petro
Lincoln Nebraska
Im intrested. I really want to get back into a 7.3 due to insurance and pickup payments. My 6.4 has 107,000 miles, let me know if your intrested. P.m. me
TyCorr
Wow! That truck is nice. Its perfect in every way, honestly. Those.wheels.were.designed for.that truck.
05chevy
Bump for a well built truck. Runs good. Pulls my truck to the track very well. :D
Strokersace
Towanda, KS
Makes me sad. Gorgeous rig and I wish I had the money. You've done a nice job transforming the truck over the years. And tastefully too!!! Don't find that all too often...
Good luck with the sale Kris. That truck is every bit worth what you're asking!
PowerstrokeJunkie
Maryland
Wouldn't hurt to bring this back from the dead to try it again- This time i decided to pull a few of the go-fast goodies off and sell them to fund other projects i am working on at the moment. I swapped in a stock OBS long block that i know the history of, and is in perfect shape with about 200,000 miles on, has never been apart. No studs, springs, cam, ported heads or push rods in this one. Also running stock manifolds, now 175/146 single shots on a stock HPOP, same turbo and fuel setup as before. Truck currently has some front end (bumper/fender/door) damage from hitting a deer but that will be fixed before sale. At the same time i am going to put a different bed on it and have it all painted up pretty to match. I think 18,000 is a fair price with how it is going to be sitting once it gets put back together. Let me know if you're interested.
PowerstrokeJunkie
Maryland
Alright- the motor swap has been done for a few weeks now- Put a stock OBS 160k mile engine in- Now has 175/146 swamps injectors, Same wastegated irate mount now with a .83 ar s362 forged mill billet turbo. Stock recently rebuilt trans with precision converter, valve body and pump mods. DI built. Everything else on the truck is the same. Asking 18,500 now.
