2002 gets puny after a minute... finally quit...
cbuttre835
My 2002 7.3 automatic has developed a deal where it gets weak after about 2-4 miles every morning. It acts like you let off the throttle, then starts missing and loping, smokes very faint blue, and then clears up. I live a mile from the interstate and at 70 mph it'll clear up after 15-30 seconds.
Well, today I take the back roads, get a half mile from home, and it quit. Didn't have enough speed to ride it out. Towed it home, got it started on ether (disconnected IAH and GPR) and after a few seconds it would run on its own.
If Iet it idle itll run for 15 min fine. If I run the throttle up, it'll do the same thing, and lope real bad for a while, before settling down.
Fuel looks OK, didn't check the oil level (its on a slight grade) but its not old. Amsoil 15-40. Cracking drain valve with key on indicates good fuel pump flow, but I haven't checked pressure. Where do I? (no schrader valve like on an OBS)
Tach never stuttered or dropped out, and I got no CEL. Haven't pulled codes yet.
What other easy stuff is there to check?
cbuttre835
Nothing unusual; no fuel smell, no foam, level is OK. Gotta look back through my records and see when it was serviced last. (Inherited this truck but I did the maintenance on it.)
Magnum PD
VA
Need to see what your high pressure oil is doing. Could be IPR or pump issues.
cbuttre835
I had a P1211, a glow plug circuit low, iah circuit low, a P0340 CPS failure code.
Could not clear them with the scan tool I had.
I drained the bowl and changed the fuel filter. Thus far, has not acted up since (three trips).
cbuttre835
wish the one i have been trying to help with was that easy..
Turns out mine wasn't easy after all.
I warmed it up with the APCM Monday, Tuesday, and Wednesday of this week.
Was in a hurry to get to work Thursday, didn't warm it up, quit a mile from home.
AutoEnginuity (Thanks RiffRaff Diesel) arrived Thursday night. Put it on there tonight (Friday).
It restarted after about 5-7 seconds of cranking. ICP Duty Cycle was 18-20%. Ran pretty rough.
As it warmed up, ICP Duty Cycle settled to 10%. 500 PSI ICP. Ran smooth as silk. The KOER Cyl Contribution test reported #8 bad 3 times. (Isn't that the cackling injector?) The engine never changed sound though. The CC Test on the OBS trucks, it idles up fast and you can definitely tell when a cylinder is dropped.
The 10% / 500 PSI values are what I'm used to seeing on my OBS 7.3s. Do the split-shot injectors make a difference? I'd think they would.
I had an OBS truck that went through two IPR valves, as they wore the ICP DC at idle would creep up to 14-15% and it eventually wouldn't start back hot, because it wouldn't build ICP.
I wouldn't expect duty cycle to drop as engine oil thinned as it did on this truck. But, it had been in a non-running condition and had set 36 hrs. So there's that.
Gonna let it cool, and try to log data and see if I can get it to act up again.
Interested in any thoughts.
what cps do you have in it? yes the 8 is the cackle injector and always fails cct and usually #3 is from cps. looks like ipr and icp are ok. thats what they do on a cool/cold start..
