2003 e-350
rpm-inc
This was my highly modified van that is now completely stock with the exception of ccv venting to atmo. It was a work van so it has a few dings and scratches. Very little rust and still looks good. Ladder rack. Still has the built trans in it including hardened input shaft and triple disc tc. About 50k on the trans. 215k miles. Runs perfect. Every oring on engine replaced not too long ago, so no leaks anywhere. Will need tires soon, may be able to throw in a different nice set. 4.10 LS rear, can include a 3.55 open if wanted. I can also include an aluminum heated fuel tank that would need to be mounted where spare tire was.
The only reason I am selling is because I want something bigger. Located near Chicago, 60185.
5500.
EDIT-Hot heat, cold ac. The engine in it now is out of a 2000 tx van, so the oil pan is in perfect shape. Flexsteel driver/pass conversion van seats in real nice shape. Driver seat is full power. Could use the steering box tightened up or replaced.
