2003 F-250 6.0/auto roller $10k
SSpeeDEMONSS
6mi from the beach, SoCal
2003 F-250, CC SB, 6.0, auto, 4wd. only has short block in it, heads were cracked so top end is off the engine. everything worked on the truck when i parked it. hasnt been on the road since like june of 09. here is what is on the truck that i know. i pulled the 450 compressors off and there is no exhaust. i bought another engine for it, no injectors and weeping HG, i will include that with the truck. looking for like $10k obo.
003 F-250 XLT, 6.0L, 4WD, CC, SB, TqShift, 3.73
-SCT from DJ, Suncoast super duty rebuild and converter, Airdog FP-150, custom fuel system -8 to -6 feeding front and rear of heads at 65psi, 4" straight exhaust to 6" single black stack(for now), Isspro boost, pyro, & trans gauge, Autometer Ultra-Lite II fuel pressure, Quad Commander, EGR cooler delete, 3" leveling kit, bilstein 5100's, 315/70-17 BFG All-Terrains, 17x9 Pro Comp 6005's, spool, custom traction bars, custom bumper/lightbar, zoodad, steveracer, removed turbo silencer ring, high idle mod, 2Lo mod, silverstar 9007's & 9145's, TAP Impulse brake controller, airbags, acetoned F-250 badges, back up/hook up lights, Viair 480C and dual 450C, 12 gallon tank, 1/2" line, fittings, and solenoid, Seige Engineering Kong MKII train horns and 2 grover air horns
audio-pioneer H/U, 1000 watt DHD amp, 150 watt DHD 4 channel (2) 12" kicker comp VR's
build date-11/20/2002
Garrett
SSpeeDEMONSS
here's an updated list of what is has.
-has a tune from DJ(looney) but no SCT, Suncoast super duty rebuild and converter, Airdog FP-150, custom fuel system -8 to -6 feeding front and rear of heads at 65psi Isspro boost, pyro, & trans gauge, Autometer Ultra-Lite II fuel pressure, Quad Commander, EGR cooler delete, 3" leveling kit, bilstein 5100's,, 17x9 Pro Comp 6005's, spool, custom traction bars(one is bent and i can fix or remove), zoodad, steveracer, removed turbo silencer ring, high idle mod, 2Lo mod, silverstar 9007's & 9145's, TAP Impulse brake controller, airbags, acetoned F-250 badges, back up/hook up lights, Viair 480C, 12 gallon tank, 1/2" line, fittings, and solenoid
audio-pioneer H/U, 1000 watt DHD amp, 150 watt DHD 4 channel, 1 DHD 12" sub
-has 5 total of the 17x9 procomp wheels. 2 of which were cracked when i got them and because i didnt have the receipt procomp and 4wheel parts told me to pound sand. i tig'd them on the inside and they were fine. one started to leak again and the other is still good i believe.
-i have 4 16x10 axis fake beadlocks that were on it when i got the truck. all are in good shape, just need cleaning as they have been sitting for a 6 years.
$8k.
Garrett
