2004 F250 ECSB FX4 ZF6 East TN
mind if I smoke
Knoxville, TN
I have a 2004 F250 6.0. It has 170K on it. About 10K ago we pulled the cab for the second time. We put on new Ford OEM heads, Adrenalin HPOP, new DD clutch, and allot of other things. Spent a ton of money. About the only thing I didn't do was injectors. Now the injectors need to be done. Two weeks ago I bought my first home so I currently do not have the money for a new set. The truck will start and run but it runs rough and it sometime will not fire back up when it's hot. I have no idea what it is worth so I'm trusting your guys opinions. This is a great truck with allot of work put into it. Little about it, 225/100 injectors, 68mm CK turbo, full fuel system, full oil system, full air system. It does have rust in the bed but the rest of the truck is very solid. Feel free to text/ call me or hit me up on here, 865-254-6283. I'm located in Vonore, Tn outside of Maryville. I need to move this truck so I can get something else without getting totally screwed.
8WR_ZJ
Honestly since its not a running truck at the moment its kind of like buying parts. I think you would have better luck parting it out then trying to sell as a whole. Average 6.0 lariats with less than 150k bring around 10-12k. Anything that you spend on a truck as far as aftermarket you will get at .25 per dollar spent. That's what it is around my neck of the woods. I bought a 88k 6.0 7 years ago for 14k. it was a CCSB 4x4 with a ZF6 but it was a xl model. That was from a dealer too.
