2004 Ford F250 King Ranch FX4
117,XXX Miles
2nd owner bought the truck in 2014 with 40,000 miles on it in Yuma, Az. Southern truck that has only been in Nebraska since 2022. The A/C system was replaced in March of 2023 ICE COLD. No leaks, truck is ADULT owned. ARP head studs and updated with the entire line from Bullet Proof Diesel. Truck can pass a SMOG test.
Pros-
Bullet Proof Diesel Heavy Duty Air-to-Oil Cooler kit (2017)
Bullet Proof Diesel EGR Cooler (2017)
Bullet Proof Diesel 7.3 fan adapter with OEM HD fan (2021)
Bullet Proof Diesel Water Pump (2021)
Bullet Proof Diesel updated A/C Condenser Bracket (2023)
Updated Motocraft 2010 transmission pan w/ updated filter(2021)
ARP Head Studs (2017)
OEM Motorcraft Head Gaskets (2017)
KC Turbos 1.5 kit with upgraded bearing and ar housing
No Limit FAB hot and Cold Side turbo pipes with updated CAC boots (2021)
CSR intercooler all aluminum (2021)
A/C compressor, condenser, evaporator core, accumulator (2023)
Radiator (2021)
Power Stop rotors on all 4
Power Stop calipers on the front
Ranch Hand front bumper
Matching rear bumper “included not installed”
2005 style grille (2023)
2005 style headlights with led lights (2023)
Dual Steering Stabilizer
Rear Diff Cover with added capacity (2021)
4” lift with dual shocks up front blocks in the rear
Custom Heavy Duty traction bars in the rear
Towing Air Bags
Transfer case drop bracket
Blue tooth radio with mic
35” Toyo M/T
20” Helo wheels
Turnover goose ball
4” Turbo Back MBRP exhaust with MBRP quite flow muffler
2008 style mirros
Catalytic Converter Included not installed
Body is Completely straight no dents
Interior is clean no rips or tears kind of what you would expect for a 20-year-old truck.
Cons-
1 paint chip on driver side pillar “Size of a quarter”
1 Clear Coat chip on Driver rear door “Size of a quarter”
Clear coat fading on the tops of the driver doors
Missing rear cab driver side trim piece “Nebraska Wind”
Missing 1 of the passenger glass in mirror “Nebraska Wind”
Missing Tailgate top trim
Questions let me know 308-299-0893
Located in Alliance Nebraska
117,XXX Miles
Pros-
Radiator (2021)
Towing Air Bags
35” Toyo M/T
20” Helo wheels
Turnover goose ball
2008 style mirros
Cons-
