RSK
so i looked at a 2005 6.0 i'm most likely gonna buy it, its a 2 door xlt cab and chassis, new injectors from ford, saw the 4000 dollar bill for that, new ficm, and all sensors, motor got rebuilt at reputable machine shop, new heads, new oil cooler, truck is all stock 132 on the truck and 6k on the rebuild with 12k in receipts. i get under the truck and the oil pan has some oil on it....no enough to drip onto the ground even but still more then i'd like to see. what could it be hpop cover gasket, turbo oil drain? truck is pretty clean everything works it starts perfect cold or hot, runs beautiful, only down side is it needs a titan tank still and it's throwing a sending unit faulty code even tho the gauge works, so i'll toss a sending unit in when i do the egr ****** and titan tank.
