2005 F250 6.0 lariat FX4. $5,900 obo
Strokethis34
West Virginia
I bought this truck with intentions of fixing it up. But plans have changed as always. I really need to get my king ranch running again. But it's a 2005 f250 lariat with 6.0, fx4 4x4. It has 178,xxx miles. I bought it with the rad,CAC,fan,shroud, blower motor, vaccum pump,and steering box missing.
I've got everything but the gear box and blower motor/ resistor and vacuum pump. I put a newer ficm in it and new oil/fuel filter housing in it. I did get it to start but I shut it off because I didn't have the fan installed. Since then I couldnt get it to restart. Maybe old fuel? It's been sitting awhile. Also might need new batteries or starter. It was a work truck and needs a lot of TLC. But if anyone wanted a puller or drag truck?
I also put new trans cooler lines on the front to the radiator. The tires are around 80% tread left. Clean title in hand. I need to move this thing. I have other priorities right now. But if I can't sell it I'll try and get it running later down the road.
Asking $5,900 obo
Located in charleston,WV
Must bring trailer to get it.
Please call/text for more pictures/info. 304-55zero-4two54
Thanks
WILD_PHIL
East TX
I believe you could part it out and make that or more if it doesn't sell. Good luck.
E99 F350/zf6/guages/arp/comp/stellite/ billet wheel/ bellowed... Need more fuel and more air.
