The only difference, I think, with that bearing over a SRW bearing is the lug studs.
I believe it is a 8x170. Ford uses a adapter to get the 8x200 pattern in the front.
The studs are usually shorter on the drw bearing and they kept the older 14x2.0 thread pitch.
If you switch the studs out it should work for either.
