2008 F250 6.4
gotchadollar
Selling for a friend. I know some things will be missing in the ad but I will fill them in to the best of my knowledge.
2008 f250 6.4 4 door
Valve springs
Push rods
H11 studs
De lipped and coated hd pistons
60% overs on new injectors
Rcd billet cam stage 1
Cryo treated rocker assembly
Midwest dual fueler kit
2 new hpfp oem
Bpd water pump
New oem front cover
New oem high output alternator
New oem power steering pump
New oem ac compressor
Alradco radiator and intercooler
No limit cold side pipe
Elite diesel Jr. High powers 59/76
Beech fuel bowl ******
Heads were re done with the motor has 7,000 miles on the setup
Rudy’s full billet trans
Billet flex plate
Traction bars
Bmf Sota 20x10 with toyo proxies
New oem oil cooler
All new bearings and seals in block.
Lowered with 4400lbs springs still retains factory block in rear.
Has turn over ball hitch
No limit CCV
No limit intake
SCT tuned by Cale
Truck runs a consistent 11.6-11.8 @130mph
@4300ft elevation
Any questions I will try to answer them ASAP
Thanks!
gotchadollar
Asking $28,000.00
Miles is at 208,000
Lariat, heated seats
gotchadollar
Apologies for the side ways photos
bigrpowr
<How I Fly
Valve springs
Push rods
H11 studs
2 new hpfp oem
Bpd water pump
New oem front cover
Billet flex plate
Traction bars
New oem oil cooler
No limit CCV
No limit intake
SCT tuned by Cale
@4300ft elevation
Thanks!
time slips please ???
gotchadollar
I was off on the MPH here are the time slips.
