2008 F250 King Ranch CCSB
fubolislif22
2008 F250 6.4 King Ranch CCSB fully loaded minis sunroof:
The engine is basically brand new with the new enhanced shortblock and milled heads at about 120k.
Xrt pro race tuner (mild tune)
EDGE 2 monitor
New Coolant filter kit
New alternator
CCV reroute
ARP head studs
New High pressure fuel pump and fuel lines
New High pressure cartilage
New injectors stock OEM
Beans Sump kit
New Milled heads
New Enhanced short block
Flo pro egr ******
S&b cold air intake
New up mbrp up pipes
4 inch exhaust turbo back
New fox 2.0 shocks
2" level on 20x12 fuel rims
N-Fab step bars
New Daystar body mounts installed
20x12 fuel rims
Husky laser fitted floor mats
5th wheel goose neck
Has rear view camera mounted in the ford emblem but needs to be plugged into the head unit (wires are already ran to the front).
141k on body in great shape, but daily driven so it will go up
ASTAR LED/switchback conversion for all lights on the truck including headlights/fogs
JUST CHANGED ALL FLUIDS WITHIN TRUCK (front differential, rear differential, torque converter and transmission oil including trans filter. The coolant has been flushed with ELC (extended life coolant) and new oem thermostats were installed.
Just had oil change done and replaced both fuel filters and always use motorcraft. (3k on oil and 6k on fuel filters is my maintenance schedule) Diesel kleen fuel additive added to every tank.
Sure I'm missing some things but the truck is great, shifts amazingly.
Clean clear title in hand. NO RUST!
Only thing the truck needs is a new steering gear box, common issue. It doesn't bother me so I never replaced it.
Any questions let me know, shoot me a text 630-333-3401
$26,500
fubolislif22
here are some more pics...
fubolislif22
and some more,.,.,.
fubolislif22
any interest or offers? Need to sell, would consider trading for a 99-03 7.3 CCSB plus cash on your end.
fubolislif22
Where's it located? Also, what does "enhanced shortblock" mean? Are the pistons delipped?
Last one... 5th wheel and gooseneck come with it?
PM sent, and right outside Chicago in the southern burbs. gooseneck/5th does come with it.
fubolislif22
anyone looking for a clean rust free king ranch... open to offers, shoot me a text 630-333-3401
