2012 6.7 low oil pressure light
lazlow
Trying to help a buddy out with his 2012 6.7. It's been tuned and ******d for at least 60k miles with h&s and the issue has just popped up. Getting a low oil pressure warning. Put a mechanical gauge on it and it showed 65psi so it has pressure. New sensor made no difference either.
The only codes coming up were U0106 and a code for the maf sensor. Fuse 36 under the hood was blown so I replaced that and the codes have gone away but low pressure warning is still up. The nox module is unplugged which I heard effects this so that's not an issue.
And ideas? Or does anyone have a wiring diagram so I can test the pins?
Mesa, AZ
If i remember right there is a bcm reprogram or an ic reprogram for this concern. I dont know what that will *** with as far as tuning goes. The bcm reprgrams all sorts of stuff when it does it.
