bad moose
I have a brandy new service truck. F550 with a maintainer bed and crane I scale at 18860 lbs and just put on the final piece to the truck. A 450 lbs Trailblazer welder. Well all was fine and dandy before the welder, the truck now leans 2 to 3 inches on the rear towards the drivers side. Go Figure.
The welder is mounted on top of the toolboxes at the rear, air compressor at the front on the drivers. The crane on the pass side. Bed mount is not an option but would work the best just not enough room. and I have to watch my weight, can't go over 19500 lbs, I'm at right around 19250lbs right now.
Was thinking air helper springs but know nothing about them pro's or con's. Also if any vendors could help depending on options and thoughts.
