2015 injectors in a 2011
Can I run 2015+ injectors in my 2011? I already have a 2015 pump and a streetmax x. Besides programming the new injectors IQA codes would I need my tunes rewritten for the new injectors? Is it even worth it to upgrade to the 2015+ injectors or should I just get the 2011's? Truck starts and runs fine but I've noticed my fuel balance rates get worse over the past couple months. This was what they were at today.
08Monster
As far as I know, they are the same thing.
Sent from my Moto Z (2) using Tapatalk
Yes you can run 15 injectors in an 11, no you dont need your tunes changed, yes you will need the codes reprogrammed. The body size is slightly larger on the 15s but that makes absolutely no difference if you are retaining stock nozzles. No power gain to be had so unless they are the same price as replacement 11s, it's not worth doing.
That's what I was needing to know. Thanks.
Do these balance rates look bad or are they fine for now? I was told they should all be with in 0.5+ or -.
After looking into the costs I may just get the 2015 injectors because I came across a good deal on a 2015 pump, new Bosch injectors, hold down bolts, supply tubes, and washers all for $2,224.23 with free shipping and no core charges from fordracingpartsbydonwood. Then I can sell the 2015 pump for $800 and get new injectors and hardware for $1,400. IMO this is the way to go to get the best deal. I looked into remans but I'd rather get new since I've been burned before. The guy I sold my old S363 kit said he'd be interested in buying the pump but if it doesn't work out I'll be listing it for $800 with free shipping.
