22.5 diamond enterprise adapters
SmokeyFreedom
Brookings SD
I have Americans on mine. These look slightly lighter built and if you run in salt/lots of mud, then solid centering ring is going to cause a lot of corrosion. That being said, these are noticeably cheaper.
FYI, Twin steering stabilizers, bags of Equal in the tires, and good ball joints are a must! you'll also lose about 20% to the ground compared to same height 16's. INCREDIBLY large rolling mass! But highly highly worth it. Id do a 255/70R22.5 for tire. 275's like I have, have NO options for heavy tread
