225/100's and a 66/77/.90 Billet wheel only 410HP.
7.3psd97444
Indiana
sorry for the slight derail OP, but what charger are you running? Im running a 64/77/.95..
EDIT: nevermind lol, I think I found it
Got on the Dyno at TS and only put down 410 with 225/100's and a 66/77/.90 with a Billet Wheel. I did hit 1050ft.lbs but was kinda hoping for somewhere around 6. I was running erics X race tune. The guy said it kept downshifting on the dyno like it was a built tranny and it is not. It runs good in the tune but I dont know why I would only be putting down 410? Any Thoughts?
:toast:
Pizza pig
MD
does borg warner even sell a 77mm exducer wheel? or are you talking about inducer? The 68mm turbine wheel (exducer) has a 76.3 inducer.... sounds like a 66/68/91 to me from bullseye.
Im not real sure if 225/100's and a 66 could make 600hp...I could be wrong, but just dont seem like it would be enough.
64mm turbos are known to make over 600 on fuel with 225's, 66mms are good for a lot of power man, as long as theyre holding icp.
JWaltz
I dont know for sure what the exducer is I wanted a 74 but I got it from a small shop called TDI in indy saved alot of money and picked it up the same day I called Ill have to check my papers. I think its a 77
jdc753
Norton, MA
dang when I read the numbers on the board for your truck I assumed it was just another race tuned 6.0. Truck looked good though!! Shame the dyno was reading soo low for everyone. I'm sure the heat didn't help, but certainly doesn't explain how low the readings were.
JWaltz
Ok it probably isnt but thats what I thought it was I will have to check.
motoxracer42
I dont think it exists lol, the only wheel that comes to mind is a 68mm bw turbine (76.3mm inducer)
300 framed chargers usually are labeled by turbine exducer lol. if its a 68mm exducer then you probably wont make that great of power. i would imagine more than 410 though.
JWaltz
Like I said ill have to look at it tomorrow and see for sure what it is but it takes forever to light but when it lights it hits around 40 PSI.
