25% discount on ford parts to members
zilla68
Moore Oklahoma
hmm. wonder what the difference is, I got that number off another site as a replacement. I'll check it out and let you know.
genie144
Under a Tinfoil Hat
All parts for 2002 F350 SRW. I want to rebuild the front end.
upper ball joints x 2
lower ball joints x 2
Yellow o-rings x 2
Axel Dust Seal x 2
Wheel Seal x 2
lower ball joint snap ring x 2
Upper ball-joint nut x 2
lower ball-joint nut x 2
o-ring kit (includes 1 snap ring and two black hub seals) (5C3Z1K106AB) x 2
Cotter pins x 4
Studs to connect hub bearing to knuckle x 8
Nuts for above studs x 8
Hub Unit Bearing Assembly x 2
Inner tie rods x 2
Outer tie rods x 2
the ball joint that the trac bar connects to x 1
the drag link ball joint that connect to the pitman arm x 1
anything else that I might have missed?
I am looking for this same quote for a 2002 4x4 f350.
Sam
builtfordtough
Quote please
2x 2C3Z-5310-AF X-Code leaf springs
4x F81Z-5705-ZA U-Bolts
8x N805480-S426 Nut
2x 3C3Z-5560-CA B-Code Leaf Springs
2x unknown part numbers F350 3 1/2 inch tapered rear blocks
4x unknown part numbers U-bolts for the above
8x unknown part numbers Nut for above U-bolts
Shipping to 28314
sunrisefordparts
8x N805480-S426 Nut
Shipping to 28314
for blocks and u blots and nuts i would need an application or a vin of a truck that has what your looking for
2C3Z-5310-AF list $230.98 each sell $173.23 each
F81Z-5705-ZA list $26.13 each sell $19.60 each
N805480-S426 superceed to w520115-s440 list $2.00 each sell $1.50 each
builtfordtough
doing the x/b mod to an 02 excursion
builtfordtough
8x N805480-S426 Nut
4x Ubolts for 2002 F350 single wheel with overloads.
8 Nuts for Ubolts above.
Thats all the parts i need Shipping to 28314
sunrisefordparts
Would you mind PMing me or posting the quote? I wasn't the original requestor but I am looking for basically the exact same thing.
Sam
sorry bout misunderstanding. see attachment for quote
  • Q256308.pdf
sunrisefordparts
8x N805480-S426 Nut
2C3Z-5310-AF x2 list $230.98 each sell $173.23 each
F81Z-5705-ZA x4 list $26.13 each sell $19.60 each
N805480-S426 suoerceeds to w520115-s440 x8 list $2.00 each sell $1.50 each
3C3Z-5560-CA x2 list $293.11 each sell $219.83 each
F81Z-5598-FA list $96.78 sell $72.58
F81Z-5598-GA list $92.45 sell $69.34
F81Z-5705-EA ubolts x4 list $21.99 each sell $16.49 each
N620485-S441 nuts x8 list $3.63 each sell $2.72 each
