285/75r17 on 2014 dually?
Sicksoh
Shaunavon
Hey everyone so I have done some searching and have some info but all the posts were fairly old so thought I would see if there is any new info out there. I have a 2014 350 dually and want to run 285/75r17 tires on the factory rims. Now We tow a 16000 lb fifth wheel a lot. Do I need to run a spacer? I have heard some people say no and some say yes a 2" but all those threads were back in 2011. So now that we are a few years into the new style duallys, is anyone running this setup? How much do the stick out? Pictures are always awesome too. Thanks.
Jayz
That's a 33.8x11.22 tire....I'd say a 1" spacer is good, 1.5" even better! For 12.5 wide normally a 2" spacer is used and you'd about .5-.75" of space between them.
Jayz
Yessir! I just put 37-12.5 on mine today with a 2.5" spacer to make sure I have enough clearance between them with a load! I did a ton of research like 2 weeks worth so it's pretty fresh in my mind. As you know, they're ain't much info out there on duallys
Jayz
Here's mine with 2.5" up front and factory f350 single wheel 3.75" block in rear. 37x12.5 nitto mt with 2.5" spacer between duals
Jayz
Side shot
Whitezotti
helotes texas
i have a 2" spacer for my 06 f350 dually but it was too big. im almost 100 percent sure they have the same bolt pattern. but i also got american force classics 19.5s when i had stock rims i definately needed spacers and i only had 34" tires im pretty sure they were 285s are 285's like 34" tires? i would reccoment at least a one inch spacer
Whitezotti
helotes texas
if you go to discount they wont mount them for you every year they get strickter and strickter about how wide of a tire they will put on a narrow rim. they practically wont touch duallys and they absolutley wont touch spacers. i guess laibilities. in the past five years i use to get my duallies tires mounted there and now i practically have to do it myself. about 2 years ago they did my 285s on the stock 17's once i had a blow out they warrantied them and they wouldnt touch it unless it was a 265. which screwed me over because i got 6 tires lol
