powerstroked08
Yes like B585Ford and madman said skip the ported rails. And madman is right that the low pressure pump isn't going to be a power adder, but with say a fuelab and a fuel bowl delete. You can get the fuel filtered down to 1 micron if you want( with the correct filter) it will clean up the engine bay, and the filters are easier and cheaper to change(even though you spend good money on the fuel system). Plus you won't have to wordy about the water separator getting gunked up and not working like on the stock setup.
