300/200s, Irate T4 Kit, GTX4294r
SDstroker
SE, SD
GTX4294r w/ 1.15 housing $2200
Irate T4 Kit (non gated) $1200
Turbo and T4 kit together $3200
Swamps 300/200 (aprox. 20k miles) $1800 plus cores
All have about 10K miles on them unless otherwise stated. All parts are still on the truck so I will need a weekend to tear everything out. By far the best setup I have ran. Thanks for looking.
SDstroker
SE, SD
Should add there is no shaft play. Only 7K miles on the turbo. Turbo comes with coolant lines that I T'd into the heater hoses and Hot side pipe.
SDstroker
SE, SD
GTX4294r w/ 1.15 housing $2100
Irate T4 Kit (non gated) $1000
Turbo and T4 kit together $3000
Swamps 300/200 (aprox. 20k miles) $1700 plus cores
Should note that the turbo comes with the hot side pipe since the pipe is made to run with the turbo also comes with coolant lines that I used to tap into the heater hoses.
Everything if off and ready to ship. Adjusted the numbers a little bit. Prices are shipped.
SDstroker
SE, SD
I had then tuned down to where I would have no smoke with the 1.15 housing. Still spooled about as good as a stock turbo. It lights indescribably fast. I wouldn't be afraid to run in with stock injectors even.
