305 50 20 will not go on new fuel wheels...
jimdawg185
Anyone know of any tricks getting nitto 420's 305 50 20 on 20x12's.
I know that there are a lot of yall doing it, so why can't my tire guys get them on there???
powerstrokedkid87
New Jersey
fit just fine...probably need to use a cheater to get them mounted up. That's what my guys had to do
jimdawg185
They said they tried that, I just thought there was a trick I could pass on to them.
johnp115
Southern MD/Charlotte NC
try laying the wheels on blocks and having the tire hang freely, and use a cheetah, thats how i got mine on. And my tires came off a 10in wide wheel so they weren't as easy as brand new tires are
David N
Eastern NC
Get 2x4 or any piece of wood cut to the length you want, and put them in the tire and leave them for a day or two. That should stretch the tire out some.
getstroked27
Friendship, MD
LOL okay heres the deal, im with mink, i have 35x12.50's on 22x14's. get a clip on air chuck, and two nine gallon cheetahs, hit both at once. should go no problem. if that doesnt work, leave the chuck on and hit it with ether. no one needs hair on their arms anyway. I used ether on my setup, took e 25 minutes to have all four mounted.
Jbenso127
Centrallll Florida
Ether, cheetahs, all good recommendations. That's what I've always done. Also, a cold tire is a bastard to mount. Leave them out in the sun and they will get a lot more pliable. Make your (or whoever is mouthing them) life a lot easier.
jimdawg185
They are going to try leaving them out in the sun. I'd take them somewhere else, but they are a great customer of mine, and sold them to me at cost. So it wouldn't be a great idea.
PDT1081
Bowling Green, OH
When they go to mount them, wrap a ratchet strap around the center of the tread. As you ratchet it tight, it will start pushing the beads out.
01pwrstkr
Polk County NC
I forgot about the ratchet strap. Sometimes using ether with the strap will work. But either way when using the strap make sure to release it after the bead is set (especially if you have it really tight) because the pressure of the tire expanding can cause it to snap. And it's a motha to release when it's that tight! Lol
DEEZUZ
NO PUKESTERS
NWI
you have to remove the core from the valvestem, that way after the cheetah hit your sending full pressure into the tire
jimdawg185
Can ya'll believe these are still not on the wheels.... These guys are a great shop and a great customer of mine. But Im in a tough spot because I really want these mounted so I can drive on them before snow falls...
Hendrys2009
Baytown, Tx
When do this all the time. We have different size rubber donuts that fit tight around the wheel. just push them up against one side of the wheel and start filling with air. one the tires stretch the width of the wheel it will push the rubber donut off. no loss of hair, no problems.
