4" Skyjacker Lift with Pure Performance Prodigy Shocks
TXAG07
Little Elm, TX
I have a used Skyjacker 4" Lift that came off my 2008 F250. This lift fits 2005-2010 Superduty.
Everything from the link below is in the link besides the steering damper and u-bolts for the rear.
http://skyjacker.com/product.php?ProdID=35150
Includes:
4in Coils, trackbar bracket, radius arm brackets, drop pitman arm, brake line brackets, rear lift blocks, steering damper bracket, extended sway bar links, all hardware besides ubolts. Kit is around $1000 new
Shocks were custom built for this kit to my specs. Below is info about them. They are exact same as pictured except I did not put the sticker on them. Shocks are $700 new. Only have 15k miles on them.
http://www.pure-performance.biz/category-s/2012.
Will try to update with pics. Can send upon request.
Asking $900
Located in Dallas, TX
TXAG07
Little Elm, TX
What's different between the 10 and 13s? Can it be made to work?
That's a good question. The coils, shocks, pitman arm, rear blocks should all be the same. So it would come do to whether the track bar bracket and radius arm brackets are the same. I'll try to do some searching and see what I find.
TXAG07
Little Elm, TX
That is very odd. They worked before. Those are the correct parts.
Thank you so much for your help cccj and the bump.
Willing to help out with some shipping. I'm willing to take any reasonable offer.
