4r100 question
RiVerBum01
lebanon, tn
Guy at work asked me a question about his 01 f350. I'm no transmittion expert by any means so I figured I'd ask you guys. He says that his transmittion sometimes seems like it has 5 shifts when it's cold out. It rarely does it when it's warm. I told him maybe it was his torque converter locking but I wasn't sure. His truck is all stock, never had any programmers or chips on it at all. I think it has around 220k miles. He asked a few ppl that he knows and someone said it was a cold gear in the transmission LOL. He is pretty smart when it comes to anything mechinacal and he drove a semi for years so I'm sure he knows what a shift is. Anybody know what could be causing this?
GatorBaitR6
Gray, TN
Transmission not as smooth when its cold and old and the TC locking is rougher then normal...? Thats about all I got... I know when I first bought my truck and i took it to a shop for the oil cooler replace I was a Newb and thought my 6.0 had a six spd automatic... when in fact it was just the TC locking..
CurtisF
TC lockup in these trucks can feel like having a 5-speed at times. Play with the tuning just a bit and it can feel like that all the time.
RiVerBum01
lebanon, tn
Well shouldn it be 1-2,2-3,tc lock, then over drive. Somehow there is a 5th shift somewhere. Maybe the converter is locking, unlocking, then lockig again? He said usually the truck is lugging pretty bad when it shifts normally, but when this 5th shift happens the truck doesn't lug down as bad.
RiVerBum01
lebanon, tn
His truck doesn't have any kind of tuner on it. He said he would like to buy some kind of chip to make it shift like it does when it is cold. Figured I would try an figure out what is making the truck do this first. Then find a tuner that can make the tranny do this all the time, if it isn't gonna hurt the truck.
CurtisF
You're miss-counting. The 4R100 will feel like a "5-speed" when the TC lock doesn't occur along with the 2-3 upshift. You don't get 5 different upshifts, you get what feels like 4 (just like counting a 5-speed). Which by the way when the TC does lock up immediately after the 2-3 upshift, that's when you get the lugging.
Cold shift strategy is different than warm shift. It's normal.
Tuning changes can move the speed/pedal position for the shifts. The same can be applied to the TC lockup.
RiVerBum01
lebanon, tn
I understand what your saying. But even counting the tc lockup, and the truck remaining in 1st gear when stopped, there should be only 3 up shifts and converter lockup. So the truck should only feel like it has 4 shift changes.
Could you send me in the direction of someone that sells tuners for transmittions only? Ive tried to convince him to put custom tunes on it but he thinks it'll wear the engine out faster
lincolnlocker
Central Michigan
So your saying that it acts as if it has 6 gears total?
Should only feel as if it has 5 gears total..
live life full throttle
RiVerBum01
lebanon, tn
No I haven't rode in the truck but I do believe the guy LOL i might ride down the road and see what he was talkin about
