08REDSLED
Any help here would be great
Problem: 4x4 light flashes occasionally when in 2wd, it is not actually trying to shift into 4x4 (no noises/clunking or driveability issues) it generally does this when it rains or air is damp..4x4 does work fine when shifted into 4x4
I figured it was a connector on the transfer case getting wet causing the light to flash on/off, however when i swapped the trans I inspected/cleaned/di-electric greased the connectors, but it continues to happen
any thoughts/ideas would be great! btw great forum!
