4x4 light stays on
nathan
horicon WI
hi my 4x4 light stays on all the time. I just replaced my switch and hubs. but the light still stays on.
any ideas?
the 4x4 works when hubs are locked in switch turned to 4x4.
any ideas?
thanks
in advance
Zmann
turn ESOF switch to off= 2 hi with the truck on and in park ,, key on engine off is fine
and see if you can turn the front drive shaft by hand
suprhlr
Zeeland MI
I had the same thing with mine, light would stay on in the dash. It was the switch in the transfercase (ball plunger sticking)
Zmann
thats what I am betting
the PCM turns the dash light on by the signal it gets from the transfer case actuator motors location
it has no clue what happens on the hub end of 4x4
Racer X
"it has no clue what happens on the hub end of 4x4." That's a Fact! LOL :D
What the PCM will usually do is go into 4x4 low shift strategy when the light is on. Nathan, have you noticed any change in shifts?
