02' F250 super cab 4x4 265-75-16 tires. Front has about 2-2.5" of lift. I had a broken rear main spring. Since I've had these 5" Pro Comp lift springs I had them installed. I had the stock 2" block installed ATOP the lift springs, then the stock overload springs installed, and finally the stock over load block like piecee. It now actually sits with the rear above the front. No more dragging ass. My pinion angle is off now. Pinion is almost straight with the driveshaft instead of a slight downangle. Needs ideas for proper shim (angle °) and would I need a carrier bearing drop? Its the equivlent of 2.5-3" lift per hitch height increase.
