swinky
I'm looking at going to a shorter tire and I know the 1-2 shift will be god awful and happen 15ft out of the hole. I want to run a 27.5 inch tire and leave the line in 2nd, get about 20ft out and hit the lockup switch and nitrous shortly after.
The 5r 2nd gear is 2.22:1
The 4r 1st gear is 2.71:1
If my math is right a 5r in 2nd with 27.5" tires will be about the same as a 4r in first with 33" tires. I think that's acceptable.
If this works out the 330ft will improve greatly, it will get into 6th quicker and make one less shift.
Now can it be done just through tuning, pcs, wire a switch into a solenoid?
