5r110 pan bolt size
windrunner408
Like the title says, does anyone know what size bolts are used to hold our tranny pan on?? I currently have a Maghytec pan that I am swapping out for an 08 pan and filter so I cant use those bolts as I think they are too long.
range91
michigan
M8x1.25 thread 1 inch long but most will be 13mm and wont have integrated washer best bet would be dealer order by ap
range91
michigan
i was off a bit on length but thread size and pitch is right factory bolt length is a fuzz over 1/2 inch sorry but still go oe part #N811266S437 should of pulled the calipers out before i posted that will learn me
windrunner408
Well what I am going for is a cap screw with a round hex driver head on it. That and some washers should do the trick. Thanks again man and take care.
