chappy
Well my suncoast convertor grenaded And I am assuming from a bad pump. Either way the pumps trashed I'm sure so I'm gonna put a used trans in. I can get one locally for $650-1200 out of 05's with 20k-100k miles on them. I want to avoid a 04 trans due to the pin backing out problem on the reverse hub. SO doe anyone know if the 05 trans will work in the 04? I actually can only find 1 04 locally but for some reason lots of 05's . Only problem I could see would be a ecm compatible issue but notsure. Anyone know?
