6.0/365 overhaul kit
dieseljunkie12
brand new in the box, a lot of these sensors and o rings and bolts also fit the dt466 engines. looking to get $1200 shipped or make me an offer.
KIT,ENGINE OVERHAUL : Per each
Part Number Description Quantity
1171851R2 O/H KIT INSTRUCTION SHEET 1
1171962R1 INSTRUCTION SHEET 1
1813354C3 CAP ASM,OIL FILL 1
1817958C1 BOLT (M8-1.25 X 30MM) 2
1818279C1 BOLT 2
1820878C2 SEAL, FRONT COVER 1
1822712C1 GASKET,DRAIN PLUG 1
1823790C1 O-RING 1
1828127C1 BUSHING,CAMSHAFT 5
1828310C1 PLUG,CUP 38MM 10
1828336C1 WASHER,COPPER 4
1828345C91 SENSOR ASM,CSHAFT 1
1830941C1 SEAL,ORING 2
1831198C91 PKG,WATER DRAIN VALVE 1
1834256C1 O-RING, OIL PICK-UP TUBE 1
1834937C2 BOLT,CONNECTING ROD 16
1835010C1 PLUG,CUP 16MM 5
1835191C1 GSKT,RESERVOIR COVER 1
1835339C1 O-RING,SAE 018 90 DURO. 1
1835732C1 GASKET,REAR SEAL 1
1835733C1 GASKET, REAR GEAR COVER 1
1835741C1 SEAL,ORING 16MM 5
1835743C91 PLUG & O-RING ASM,16MM 2
1835985C92 SENSOR ASM,CAM 1
1835992C2 BOLT,M12x1.25x59mm 4
1836078C1 ORING 1
1836517C1 GASKET,ROCKER ARM CARRIER 2
1836537C91 SNSR ASM,ENG COOLANT & 2
1836539C91 SENSOR ASM,INTAKE MANF 1
1836550C1 O-RING,EGR COOLER 1
1836749C1 GEROTOR ASSEMBLY 1
1837503C1 SEAL,O-RING 1
1837623C1 SEAL,O-RING 8
1838136C2 SEAL ASM,VALVE 32
1838250C1 GASKET,VALVE COVER 2
1838394C1 SEAL,O-RING 3
1838520C1 GSKT,OIL FILTER MTG 1
1838526C2 STRAINER PUMP,INLET 1
1838603C1 VALVE AY,OIL DRAIN 1
1838614C1 GSKT,COOLANT INLET 1
1838616C1 O-RING(112) 1
1838617C1 O-RING,SIZE 218 2
1839304C92 THERMOSTAT ASM 1
1839415C91 SENSOR ASM,ENG OIL 1
1839592C1 SEAL,M12 VITON 2
1839620C4 GASKET,EXHAUST TUBE 1
1839671C1 SEAL,RETURN TUBE 1
1840053C96 KIT,TURBO MTG 1
1840697C2 SEAL,PRESSURE O-RING 1
1840701C92 KIT, INTK MANF GSKT 1
1840729C1 SEAL,O-RING 1
1840749C92 KIT,FUEL FILTER SEAL 1
1840752C91 KIT,OIL FILTER ELEMENT 1
1840777C91 INTAKE THROTTLE GS KIT 1
1840778C92 KIT,EGR VLV SEALING 1
1843028C92 BRG SET,CRKSHFT 1
1843258C2 SEAL, DIPSTICK TUBE 1
1843286C2 PLUG,GLOW 8
1843501C1 O-RING 1
1843543C1 GASKET,LOWER OIL PAN 1
1843556C1 BOLT,M8x45 TORX 3
1843571C1 GASKET, UPPER OIL PAN 1
1843682C91 KIT, INJECTOR SEAL 8
1843914C1 SEAL,ICP SENSOR 1
1844156C1 SEAL,BREATHER FACE 4
1844447C1 SEAL (EMD-1484) 1
1844634C1 SEAL,O-RING 1
1844987C91 COVER AY,GEROTOR 1
1845251C91 KIT, FRONT COVER SEAL 1
1845428C92 SENSOR ASM,ICP 1
1845469C1 INSULATOR,EGR COOLER 2
1845607C91 KIT,PISTON,PIN & RING (.010) 8
1845851C91 FITTING,MAP SENSOR 1
1845852C91 FITTING,COOLANT DERERATION 1
1846575C1 PIN,SPRING DOWEL 4
1846975C1 O-RING,SIZE 317 2
1846976C1 O-RING,SIZE 319 2
1846977C1 SEAL,EGR COOLANT SUPPLY 1
1847085C92 KIT,HYDRAULIC PUMP SEAL 1
1847100C97 KIT,HEAD GASKET & BOLT 2
1848131C91 KIT,ROD BEARING 8
1850307C1 GASKET,CYL HEAD 2
1855240C2 GASKET,EXHAUST MANIFOLD 2
1858091C91 KIT,LOWER CRKCSE SEAL 1
1858198C1 BOLT,EXH SHOULDER FLG 4
1858331C1 OIL COOLER 1
1872161C1 ADAPTER ASM,BRANCH TUBE 1
1878255C91 KIT,CRKCSE RR OIL SERV 1
40066R1 NUT, M8 HF LOCK 6
S0057E2 BOX FOR 6.9 & 7.3 WORKS KITS 1
S0506E1 CARTON (22X9X1.25) 1
S0606E1 RING BOX (5.5x5.5x3) 1
